Good luck finding the clutch fork and bellhousing if you don't already have them. You can get the pedals and everything else aftermarket (ecparts.net, dixiemontecarlo.com, etc.), I haven't seen the stock G-Body bellhousing/clutch fork being reproduced yet (you may be able to get an aftermarket bellhousing though). If you run a Saginaw trans you can use the stock TH350 yoke/driveshaft, I'm not sure about Muncie/T10. They're more fun, but a little bit of work to change everything over (not complicated by any means). It is possible to run a hydraulic throwout setup if you need to though.
