78-80 Monte Picture Thread
Good luck finding the clutch fork and bellhousing if you don't already have them. You can get the pedals and everything else aftermarket (ecparts.net, dixiemontecarlo.com, etc.), I haven't seen the stock G-Body bellhousing/clutch fork being reproduced yet (you may be able to get an aftermarket bellhousing though). If you run a Saginaw trans you can use the stock TH350 yoke/driveshaft, I'm not sure about Muncie/T10. They're more fun, but a little bit of work to change everything over (not complicated by any means). It is possible to run a hydraulic throwout setup if you need to though.
dfischbone said:
Just trying to keep up with the Jones'...Thanks to Tony for my avatar!
Nice. Any plans on bringing it closer to the ground? I love a little rake on MCs
I am new here and thought I would post up a pic of my Monte...It is a '78. I got it when I just turned 16 back in '87 I will get some before and afters up, but this is the latest one.
Just received my new switch plate and extensions for my 79 yesterday 😀
Reactions: smokybob
MC in Japan
donnyR said:
My pic won't post
Make a acct at photobucket.com, up load the pics there, and then copy the img code under the pic on photobucket and post it here
