Maybe test compression if the starter isn't smoked and/or you put one on it. Have you tried starting fluid?
It has a little over 150 like 175ish didn't have my glasses on but I could tell it was good on the gaugeMaybe test compression if the starter isn't smoked and/or you put one on it. Have you tried starting fluid?
Tried starting fluid it's getting gas anyway got spark moved the distributor like a million timesIt has a little over 150 like 175ish didn't have my glasses on but I could tell it was good on the gauge
It has fuel, spark and compression. It should be in time. It should run. I totally understand your frustration. I wish I was there to help. Could it be a bad distributor cap or something like that? I've had some new parts bite me in the *ss.Tried starting fluid it's getting gas anyway got spark moved the distributor like a million times
New cap looks good new rotor looks good used in cap msd coil tests fine new 8 mm wires new AC platnums fire oem gm module working it's one of the wight ones never seen a bad one of them has spark got it to fire just not correctly then for a moment I thaught it was going to go and the starter got hot and started sounding like a meat grinder and getting way to slow so I gave up for the nightIt has fuel, spark and compression. It should be in time. It should run. I totally understand your frustration. I wish I was there to help. Could it be a bad distributor cap or something like that? I've had some new parts bite me in the *ss.
I'm watching the unibomer on TV maybe I'll get some ideas for the car lolMaybe you are there and the starter is just done. I hope so. You have our support. I asked about the cap because I had a new, bad cap tear me up in a slant 6 about 25 years ago. Ate me alive.
