Well not only did I ruin the tuna my car sucks to!
Came home today and decided to try and get the brakes working right rear bleeder is broaken off so I bled it at the line left rear no problem right front was clogged took it out and drilled it. Left front rounded smooth out. Got it loose tho beating a pair of vice grips with a body hammer. I let it bleed wile I ran to the store for a new bleeder and Bam the brakes work....sub par but work next I got back under the hood hooked up the trans vacuum and filled the trans topped off the leaky cooling system and tried to road test it. That's when things got ugly.
Under a load it would not expect fuel it was powerless pooping threw the carb spitting and stalling I literally only got 2 houses away and turned around. Once I had it back in the driveway I decided to take the carb to that builder this Saturday so I ripped it off and put that carb on that came off of my 87 Cutlass when it had a 307 because I know it never had this poisonous new fuel in it. Well it ran better with that one so I topped off the fluids again and out the driveway I went up the road. Well in the first 20' I new it was bad because it felt like there was a brick under the go petle. I stayed in it anyway because my hole point was dose it shift? Well it dose not up the hill on it's own nothing until I got up to speed then it neutraled so I spun around to come back. When I did I held my gutless wonder in first gear until it finally reved up and shifted second manually. It went it well slid in like a 40yo POS I kept it on the floor and went for third drum roll pleas.....neutral! No 2-3 I let out of it and it stalled coasted hone down the hill and back in the driveway.once home I fired it back up and checked the fluids again everything is full and now it has more rockers tapping. I could take a torch to it and make a nice low mileage carbq I could do a hole hog were the front seat it and make the trunk a fire box probably have it done in a day
