Woohoo! 10K+ views on my build. This is what I used. I can't recall but I don't think the 700R4 has the same final gear.
http://www.csgnetwork.com/multirpmcalc.html
G-Body_Vet said:Broken bolt+Kroil+Heat+vice grips=out!
deanlemans81 said:Looking good Steve. how did you get that dent? You know we`re gonna ask!
I agree with your assessment with the rear gears/trans combo. I currently have a th350 for my 400 and can`t afford a built 200r4 with steep gears for now. I almost had one from a wrecked GN but the guy i was buying the trans/rear from weaseled out on our deal and sold them to someone who offered more cash after accepting my offer. For now i will keep the th350 but I did get a 7.5 posi with 2.71 gears for only $100. Not quite the tire scorcher but cruising rpm should be Ok.
BTW where did you get your body bushing kit from?
pontiacgp said:if you want to see why the c channel in the frames really ought to be boxed pick up one rear horn and lift it up to see how much the frame will twist before the other side moves...that frame is like new, even around the holes for the bushings it's in great shape...
oh and your neighbors must really like you..![]()
motorholmes said:You're making me want to do things to my car that I really shouldn't be doing :?
