Got the rear all buttoned up. Fluids in and rear cover is on. I also picked up some needed tools, Flotech headers, Stage 8 bolts lock bolts for the headers and collectors and Remflex gaskets...
You dont realize how much you need a vice until you dont have it handy. Grabbed this for $63 at sears
A tubing bender kit. imma go ahead an get the Eastwood flare kit later. Didnt wanna spend the cash for al that now when so much other stuff is needed. This kit has everything I need to do the job nicely.
installed the vise on my work bench and Im ready to get to work..
Practice run. Looks just like the factory flare.. Im re doing the lines with new tubing and ends from eastwood. Just wanted to practice on the factory lines..If I dont get new lines, I'll at least get new threaded ends for the 3/16" factory lines. These ends are so rounded of. No bueno..
cut and reflared the stock line
new line
New headers for a SBC 350..I will break the new motor in with the old headers and then install the Flotech's..
New STAGE 8 header lock bolts and collector flange locking setup. Ive got the serpentine bracketsall powdercoated up, and picked up a new belt.
Flange lock setup..
Also picked up an aluminum upper radiator hose. i had my og hose made 4 years back, and it looks like this setups pretty close to the one in my elco. A lil trimming and an elbo hose end and it will be great..
Side by side of the new pipe and my og setup in my elco..
A little trimming job and it will be perfect. im not chopping it all up. It will set in there just like my Elco's pipe sits. Imma wait to trim it down once the radiator is in the Bu. That way its set up based on that car.
Other parts ordered:
1 mini starter
2 Dizzy
3 valve cover gaskets
4 fuel pump
5 90 degree water neck
Looking good so far. Still chugging along on the wells. They are ready for wet sand now. i have 3 days off this weekend and will get a move on em. Should be ordering the aluminum heads and getting the short block started in a couple weeks. Thanks for checking back....
Elco Warren 8)
80z UP!
