Man its crazy how many options and routes you can go with these gbodys. And take as much time as you need this is my 3rd year with my cutlass and its seen a sbc, olds small block, LS swap and more than likely a big block swap. I plan on taking the body off the frame and bracing it when it warms up. Good luck with your build I have a gen 3 98-04 and some 05 MSD 6010 with the pills and disc, Holley Single Plane Intake,water pump,coil packs w/truck brackets and i believe the valve covers,ls1 spark plugs, upper radiator hose w/ the coupler and T-fitting and ICT motor mount adapters with the sbc motor mounts, Edelbrock 600cfm electric choke carb and Hedman Hustler mid-length headers w/bolts and gaskets if your interested in them message me like i said I'm going big block so I don't need this stuff. Everything listed has like maybe 5hrs of run time on them.
