Was under my 78 monte today and decided to take a detailed look at the extent of the rust damage on the frame and body and some of it seemed far worse than i remembered before parking it in a storage unit 5 years ago passenger side is in the best shape as i found nothing beyond surface rust on the frame and small rust holes on the body
The driver side got the worst of it including a large rust spot in the body infront of rear tire and bottom of the frame rusted out starting about 6 inches behind the rear axle
My question is having never done rust repair before i have been told i can use plate and angle steel to patch the rusted out frame. Is this true and recommended or would it be better to cut and weld anothe piece of frame in its place? Was also told could do something similar wit the rust holes in the body by cutting out around them and welding a piece over them then grinding down the welds as flush as possible then paint. Also meantioned a set of chrome "runners" to cover the kick panels. So suggestions? Tips?
