Some new updates from the last coupla days.
First off I got the front bumper finished up. I sectioned it 1" on the pass side as well as sectioned the turn signal opening from the donor bumper. I then cut out the area on my bumper, tacked in the donor piece and welded it all up.
I learned something new as I did this. Monday my professor and I were talking about weld "prettiness" and where I need to be at with my welding to be at a level where a decent shop will be impressed and hire me. I asked about mig welding and which was a better weld - a nice continuous bead or "stacking pennies"? We discussed the possibility that stacking pennies, although it looks great, wouldn't heat the metal enough to get decent penetration on thicker metal. So to run a test to answer my question I welded the passenger half with short continuous stitch weld beads. I used the paint shop side 120V MIG with the heat cranked all the way. If the stitches were too long or too slow it would blow a hole, so after finding a decent speed I got pretty nice welds. On the driver side I stacked pennies.
When I flipped it over I found that with that smaller welder on a thick bumper it had trouble penetrating very well either way, but to my surprise the stacking pennies actually got better penetration overall. It also had a smaller heat zone around the weld and looked a ton better :twothumbs. Too bad it's all going to get ground flat anyway, lol!
