Now for some new goodies.
I got this dual gauge pod from gbodyparts.com. They had the best price I could find at $50 including shipping. Seemed a bit steep for a mass produced thermoformed thin piece of plastic, but I guess you gotta pay if you wanna play. My interior is currently totally stripped out but mocking it up where it will go it looks like it won't be a perfect fit for my car, for sure one of the screw holes doesn't line up at all and not so sure everything else will exactly either. Maybe the wagons have different pillars? Either way I don't think it will take much to make it fit well.
Bunch of stuff from Speedway motors- My car is stock with light blue seat belts so I picked up a black retractable seat belt that will be for the jumper seat up front, an aluminum radiator hose extension tube tapped for a drain or gauge, some aluminum hood pins, a pair of circle track spindle savers, and a 9" to g-body rear axle bracket kit with the multi position LCA mounts and the brake caliper brackets, and finally my tubing notcher kit.
The fan in the upper left is from Roush Yates, it's a circle track item that is typically used to either cool the brakes or the driver. Despite being small and running off 12 volts it really cranks! I've removed all the factory big-n-ugly g-body HVAC housing and will build a custom heating system that will all be tucked under the dash, more on that as I get more parts for it in.
Next to the fan is a pair of "euro style" (woohoo, now I can pretend my car is a BMW) LED Daytime Running Lights. Cool thing is they also have built in amber turn signals so these will get mounted in the holes I created in the front bumper.
I also got this radiator from Speedway. It's 31" wide and has a "double pass" flow. With 3- 1" tubes they say it cools like a 5 core traditional radiator, and I liked this one because the inlet and outlet are both on the passenger side, just like on the LS water pump. This should help clean up the engine bay a bit. Unfortunately it's taller than the factory radiator so I'll need to modify the radiator support to make it fit.
I picked up these LS F-body rotors and ceramic pads as a kit form ebay. Joe at Bulldawg said he's had some success with these and suggested for the price they can't be beat. I'm sure they're cheap-junk Chinese parts, but so is the stuff you buy at the auto parts store anymore and this kit at $180 was way cheaper than anything local. Remember this is a budget build.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![Pillarpod.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi286.photobucket.com%2Falbums%2Fll86%2F73novars%2FPumkinator%2FPillarpod.jpg&hash=50d617de08a6c3a90400c4f36d612e4d)
![Miscparts.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi286.photobucket.com%2Falbums%2Fll86%2F73novars%2FPumkinator%2FMiscparts.jpg&hash=ed78ff1154390122bb0fc18727d39686)
![Rad1.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi286.photobucket.com%2Falbums%2Fll86%2F73novars%2FPumkinator%2FRad1.jpg&hash=48e9fa5095843287d12b71bedf6e97ba)
![Rad2.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi286.photobucket.com%2Falbums%2Fll86%2F73novars%2FPumkinator%2FRad2.jpg&hash=32723b6b38799204bd8c97e44bc9f6cc)
![Rotors1.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fi286.photobucket.com%2Falbums%2Fll86%2F73novars%2FPumkinator%2FRotors1.jpg&hash=4f1bba42a276a9db91df50023362d5c1)
