BUILD THREAD 79 Malibu wagon not slow not fast
Working on my Dmax, new to me BCM showed up Thursday..
started chasing amp draws again, found connector with the ABS pump in it pulling 3-4As,
Pulls the ABS plug, found this.. there's holes in the floorboard so that explains burning wire smell in the cab..
Plugged everything together with ABS disconnected, truck fired off the key with original BCM..
See if this picture uploads now
Also got my 75 GMC moving ish, finish up the exhaust and cooling fan shroud. Then mover her to a different corner so I can work on the wagon
Mines more the flexy side with workability
Currently has a 468/400/203 trans and Tcase are getting swapped to 4L85/241 with 14B/D60
Also had a 84 C30 454/400 that I got swindled out off.😥
Yes sir. Flexes a wee-bit more than mine. 🤣
Mine can & has worked also.
