BUILD THREAD 81 Buick/Olds Turbo Wagon 02/15/2024 More Parts!
Re: 81 Century/GN Wagon build-up 56K beware! update 7/31/13
I too want mine blacked out. I figured I would try the plasti dip on an old messed up one, then leave out in the weather for a while and see what happens. That stuff you can just peal off real quick I am told.
If you get to make the window runs before me of any of us other wagon guys, be sure to document it, lol. Or, buy enough to make a bunch and sell them!
Jim,
Spraying the piece with Plasti-dip and putting it out in the weather is a good trial method for longevity. I've actually painted my battery tray with it...and have done it to one of my former cars. It seems to work pretty well.
You can bet that I'll document my findings with the window channel and share the info with my fellow wagon guys. :wink:
So you have used it for something? Cool idea on the battery tray, that never occurred to me and is a good idea!
It's worth a try on the trim work. I'd curious as to how it would hold up and look.
The battery tray painted with Plasti-Dip is not an original idea. I kind of adopted it. :wink:
Managed to get out there last night and do a bit more cutting. I melted all the lead out of the factory joint so I can cut the pillar out where is was rotted. There were pin holes coming thru the outer surface. It looked fine at first, but it was really pitted and rotted on the backside. I tried to capture it with the pics.
Hear is the inside of the window frame, it was rotted and the drip rail was all pitted, this would come back so cut cut...
Most of the lead removed
With the lead removed and the outer skin cut away, you can see the pitted rot spot on the inside, this will get cut out too.
Just a pic from the back
Another, just closer to try and see the rot spot at the factory seam.
Here is a picture close up of the backside. Wouldn't have taken long for this to come completely thru.
All Cut out and cleaned up.
And the Jamb area.
I will rebuild this are in 2 or 3 pieces, since I have numerous bends to make. I'll cut, bend, shrink/stretch, then TIG it together.
Jim,
I've never seen the outer rear pillar rotted thru like that. The inner channel where the weatherstrip goes is a common rust area. I had to patch mine on both sides. I think the old hatch glass weatherstrip was a nasty water trap that also harbored leaves and junk.
Your doing a great job, man. I commend you on that. Using TIG makes for nice clean welds.
Jack, My brown Malibu wagon had all the pillars rotting from the inside out! That is what prompted me to look at this one. Once I started poking around the factory seam area with a sharp awe, it was just pushing clean thru :shock:
Thanks for the kind words. After I make the patches, I have to practice a few beads before I jump back into it. I don't TIG everyday, lol. Should only take a scrap piece or 2 to make sure the settings are good and all, my girls like to play around with my stuff in the shop.
Jim, knowing you buddy, it will come out great. 😀
How's that for encouragement? :lol:
A little metal fab last night.
Bent and welded the inner piece, mig welding here. There are allot of low spots, that are dark, they were just filled over with seam sealer.
Gotta use this stuff, expensive, but needed.
Test fitting this piece. Some more fitting to do, but getting close.
