On my 81 Indy pace car, the shifter cable was broken when I bought it. Guy had it removed. I ordered a replacement from gbodyparts. The original cable and replacement cable match however I’m having some issues i believe I have all the clips in the correct place to hold the cable. If the shifter cable is removed I can shift through all the gears from park to 1st just fine. With the cable hooked up it goes from park to reverse and that’s it. Is there a adjustment on these? Just trying to figure out what my issue is. I did leave the nut loose where the shifter cable slides over and you put the retaining clip on on the transmission side but even with that loose I have no adjustment. I have attached a picture of the transmission side. I’m sure I’m missing something stupid that I’m overlooking.
