'83 Cutlass Cruiser Build Thread
Been debating adding the vinyl woodgrain trim around the car once it's painted. Should I do it?
  • Yes, that wagon needs woodgrain
    Votes: 12 35.3%
  • No, leave that wagon smooth and simple.
    Votes: 22 64.7%
  • Total voters
    34
  • Poll closed .
The Buick 350 is a nice engine. I believe it's slightly lighter than a small block Chevy. You may also want to add a high volume oil pump. I think these motors had some oiling problems. Buick oil pumps are easier to change out than a SBC. They go in in front of the engine. No dropping the oil pan.
It would make a nice power plant for your Buick wagon.
Jack
Well, I finally got some swaybar links on the car, so I put a few more gallons of fresh gas in it, and decided to take it for a spin. I was mostly just itching to drive it, but I was also hoping a couple miles would help the front end settle a little bit, since I still hadn't driven it since I swapped the springs.
First was a quick loop around the block. Once everything felt o.k., I went up to the gas station down the road that is exactly 2.2 miles round trip from the house. It ran and drove well there and back, and after another quick inspection, I took it out again on a bigger loop, about 4 miles. It is fun to drive, and it runs great, though it didn't feel like the secondaries were opening at WOT. The exhaust sounds great, even though I can hear a slight tick from the passenger side that I'll have to investigate. I also noticed that my turn signal cancelling switch is broken, as the signal doesn't turn off after left turns. Right works fine.
One thing I can say for sure to all wagon owners...
Get yourself a big heavy trailer hitch!
There are no, and I mean not one, rattles or squeeks coming from the back of the car. My rusty shitbox Malibu wagon rattled and squeeked like crazy. The Buick is night and day from that, but there are still a few noises back there. The Buick has a small hitch, but it doesn't do much. You can see the big hitch on the back of the Olds in the pictues, and it's no wonder why it helps. I think every wagon out there could benefit from being a little more squeek free...
And just for fun, here's a fresh picture.
Look at that happy driveway!
like the last pic 8)
Any progress lately??
No real progress lately... been at a stand-still without parts.
I start it every now and then, and keep an eye on how much ATF it's dumping on the driveway... :lol:
I still have a few things to adjust, and then replace the rubber brake hoses to the calipers and it should be ready to put some miles on it and start shaking the rest of it down.
At the moment, my main focus is parting the Malibu out as quickly as possible once I get it back home...
Well I haven't done any work on the car at all, but I do have a small update for today...
I fired the car up with the hopes of going out to my storage container today and putting it away and bringing the Malibu back home.
Well the car made the 25 mile trip out there just fine, but unfortunately when I got there, there was a dumpster in front of my container, so I couldn't get my cars in or out. :roll:
I had brought an air tank with me to fill up the flat tire on the Malibu, so I went in and filled it, then I headed back home.
It was nice that the Olds ran and drove nice, but I was seriously pissed about not being able to get the Olds put away and the Malibu back home... Oh well, I'll try again later this week.
Drove the car another 25 miles today out to put it away.
The dumpster was moved, so I was able to get into my container.
I had to do a bit of running around, since I couldn't turn the car off. I left it running, while I opened the container, got the ramps set up, backed out the Caprice, then put the battery in the Malibu, put in some PSF, poured a little gas down the carb and off she went. Started right up after sitting for almost a year. I backed it out and then pulled the Cutlass wagon inside, then pulled the Caprice in behind it.
The Malibu made it all the way home, though I had to ride the brakes to keep the lights on because the tail lights weren't working. Now I smell like exhaust, cause it dumps right out of the converter now, since I stole the rest of the exhaust for the Cutlass...
The parting out of the Malibu starts tomorrow...
hey just a quick question, will the hood on the olds wagon you have fit on the malibu's? i think the header panel is the only difference isnt it? :?:
