I also have a 4ga. wire connecting from the battery positive to the lug on back of the alternator. Does your car have a charge light on the dash? If that bulb is out, the alternator will not receive the necessary signal to excite the alternator to begin charging.
Your brown excite wire could be open. Try running a temporary lead from that terminal to a switched +12 volt source on your fuse panel.
I've seen people go round and round replacing alternators, etc. and it turned out to be a bad wire or charge light bulb.
Thanks Jim! If you ever get the chance to send a photo of your setup sometime, please post haha. Take care.Good luck I hope u get her fixed
Correct me if I'm wrong, but there's no battery lead coming off of the alternator. It would generally go to the starter or directly to the battery.
Could that be the reason why your battery isn't charging?
Not me no. But the junkyard who sold me both alternators said they were tested, but i was told they had been sitting there in the parts bin for awhile.. Perhaps something could have been damaged...Have you had the alternator bench tested?
I'm inclined to think the 2nd alternator may be bad, simply because the original and 1st swap had the charge light in the dash go out when the motor was running, but with this one installed the light stays illuminated even when engine is on.Have you had the alternator bench tested?
Fair enough, cause yea i suspect a wiring issue, even the side posts for the battery cables are somewhat rusty and VERY stubborn to turn with pliers.I am also running a 4 gauge wire, just bought the closest length battery cable from Canadian Tire with double female ends for my 88 Cutlass. The wiring is garbage on this car and I don't trust it.
