The adjuster for the power steering is two 15 mm head bolts. I leave the lower slightly loose and just adjust the tension with a 15mm flat wrench and a bar. On that belt set up you need the A/C and power steering belts need to be on and tight or the alternator belt doesn't move or charge.
