You guys would know more about this than me,,,but.. No cruise control,, and a vac ball on the driver side at the firewall ? Isn't that 84 and up ? Unless they've been replaced ,,i cant see the indentations on the upper door panels above the pull strap...
The OP could also ck the for the pink ends on the trunk spring rod or the "factory dented " mufflers if the exhaust hasn't been replaced..
but ,,the VIN without a 9,,says not a H/O,,,like you all said ..would like to see the cowl tag
