84 Grand National lq4 turbo swap
That’s going to be TIGHT around the battery.
The ECU glove mount box looks promising, but I’d recommend against. Reason being that you have a bunch of wires that are going to have to flex every time you open and close it. I see you have all of the HVAC system, which doesn’t give you a lot of room. Solid mount would be a bunch better.
Do you need the glove box to be functional?
I'm going to have to squeeze a 3inch intercooler pipe by that battery. Will be tight. The glove box doesn't have to be useable only planning to keep my paperwork in it at most. Also I have all the factory ac components so not much of an area to flush mount the ecu. I was hoping the wiring was long enough to make it to the factory ecu location but it was too short. Also I had an idea to mount it under the center console but same thing was too short.
Reactions: Tony1968
Finishing up wiring the new gauges. Fun fun fun
They look good with the red back light
If you don't care about using the glove box, then cut the entire plastic paper holder off so that the space that it occupies behind behind the glove box can be used to make a solid mount. That way you can open the box to access the ECU. Use the center console for your glovebox items.
following... i just stuffed in a LS in my parts car that i had laying around. for now its N/A but i left the room for the turbo. man its all fits tight i see but nice job what are you using for a computer?
Reactions: Rodknok
Thank you been a long running project, I'm running a Holley terminator x max ecu.
Finally got the battery and intercooler pipes squared away. Need to get a mount for the battery and clean up the wiring some more. As of now it has dual batteries but cranks just fine off of the little battery only so I'm not worried about running the car at the track off just the little battery.
