86-blk442 said:Lookin good! Youll love those r&m looms, I have them on my olds. They really clean things up.
yep the only diff is mine are the vertical version, i got the idea from you lol thanks man
84clonewars said:The paint is a black metallic from rustolem 600 deg looks kinda charcoal gray in the pics tho. If i wanted to go crazy I could've blasted and used filler on the vc's but this was more of a test to see how much I like em. I think I will do the same to the air cleaner assembly and then run dual flex for the snorkels. Whatcha think about these guys???
Jim H. said:One of the things I did was had all my brackets powder coated and then I went to a salvage yard and picked up another set of brackets and had them chromed that way I could mix and match. Looks like your on the right path take your time another thing you might want to consider is replacing the light bulbs in the instrument cluster with leds they work great and provide better lighting for the gauges. If you ever have any questions feel free to contact me trust me I made plenty of mistakes.
olds307 and 403 said:Flat tops are no good on a 403 with #5 heads, unless you want 11 to 1 compression. Now a stock piston re ring or cast dish replacement pistons yield 9 to 1. Of course your block will need decking with cast replacement pistons, due to the shorter compression height, to reach 9 to 1.
