Blew86442 said:Sorry I don't have any good info for you like these other fine folks......but hats off to you and your build! I'm def following it!
Thank you kind sir
olds307 and 403 said:You need the basic cast pistons, unless you want 11 to 1. The KB 6 cc dish isn't big enough with #5 heads. The factory or replacement pistons are 18-21cc. Get the deep dish replacements in. 020" oversize.
olds307 and 403 said:That sounds pretty good. Beeterolds on here ran that cam in a 9.8? to 1 403. That cam has decent duration, you should be under 9.5 to 1, you should be fine.
