84 monte carlo 305 swap ?,????
chevy boii 84 monte carlo
5
san jose ca
I have a stock 305 in my 84 monte carlo non ss and was wondering should I upgrade to 350 or just pump up the origanal motor not used to 305 so need sum help id love to keep it original but love power am I going to be able to get enough power out of a 305????it already has possi rear end with quike shift in transmission every thing original jus rebuilt except engine so should I put my money into original or replace???
You can economically make decent power with a 305 and fairly recently their was a good magazine buildup showing what they did the costs and the results. That said if it were mine and I was going to do something for the Monte to be used as a full weight fast & dependable driver and wanted to stay sbc I would do either a 383 or 406. You can more easily and more reliably make the power keep the rpms down and not have it cost at least not dramatically more than re-doing that 305 or locating and doing a 350.
i agree 100%. plus, since your 305 almost certainly has worn cylinders and rings and therefore would need a full rebuild, you might as well upgrade to a 350 or larger. 350 blocks are a dime a dozen and it only costs slightly more to make it into a 383. plus the 305 is pretty much limited to 300 maybe 350HP without MAJOR work. a basic 350 will easily match that, and a 383 or 400 will easily make 400HP+.
