CUTLASS 84 supreme 305 swap (need help)
9,128
15,257
You bought a 305 12 years ago Wow you think somebody would’ve paid you to take it off their hands back then lol
$50 was the going rate for a 305 when I put it in my monte in '99. Was everything but intake & exhaust manifolds, had reman heads. Even was the correct code '81 block for a A-body. Now it sits waithing for it's trip to the scrapper.
08Malibu
1,447
3,386
North Jersey
In 99 I paid $200 for a whole running and driving 305 83 monte. I used parts from it to build my 78 nova that I later sold for barely $300, and it was straight as an arrow just needed an engine. Times change, but I still don’t want a 305.
9,128
15,257
But they make great planters, anchors, back fill, ballast, lawn art, coffee table base...
ssn696
Living in the Past
5,544
6,663
Permanent Temporary
On a budget, you can get a 350 block, bearing and piston kit and make a 350 from the 305 rods, crank, tin and accessories. Same flexplate, balancer, starter, distributor, intake manifold.
08Malibu
1,447
3,386
North Jersey
Didn’t realize they shared the crank and rods.
9,128
15,257
The 267, 305, 350 all have the same stroke of 3.48". Other than the 400 all '68 up SBC V8's & V6's can use the same rods. '55-'67 (excluding '67 350's which used the '68 up large journal) all use the small journal rods.
9,591
12,612
So he went from putting in a 305 to building an engine, probably not in the game plan.
ssn696
Living in the Past
5,544
6,663
Permanent Temporary
There were questions about why would you want to use a 305. I was offering an option what you could do later on a budget with that same 305.
