You need a square bore to spread bore. The carb you're putting on is square bore and the stock intake is spread bore. You'll also probably need to cut the line and run a short section of rubber hose with a filter off the hardline. The connection to that carb is different from the Q-Jet, and it doesn't have a built-in filter.
