Forgot about back spacing: straight edge on your brake drum and not the axle pilot that sticks out past it. From the straight edge, move your tape measure to the outer portion of the straight edges where your radius of your new tire is going to be. Make sure the jack stands are under the axle that way the suspension is compressed, and measure to the inside of the wheel house and consider the closest point to your new tire. That's the amount of back spacing you want. Then make sure that the overall width of the tire will not be hampered by your quarter panel, wheel lip, etc... When I was building my 56' I built a wooden buck that bolted to the rotor and it had a 2x4 that stuck out to represent the overall radius of the tire and rim combo. Then I made a perpendicular 2x4 that was the maximum tire widthand I rotated the axle thru a couple of revolutions with the suspension compressed to be sure there were no obstructions. Elaborate, but it works.
