So the lesson here, is steel 15" ralleys DO fit over LS1 brakes, just not super close. It will screw up the scrub radius moving the wheel out, but for a drag or street car you are fine. Run a 4th gen or c5 wheel for the backspace (and 16/17" tires which grip better since nobody makes a 15 in sticky compound) with a 1.5" hub centric spacer (my plan) and a 15x6 ralley up front with a 195/75 or so tire for drag use, and you are in business!
A 15x6 has 4" BS, and so does the 15x7. Going to the 15x6 instead of the 15x7 and the 1" spacer and this LS1 setup effectively only moves the outside of the tire out .375" so you end up with the stopping power of LS1 brakes (I have like $150 in mine total) and the ability to still run a 15" wheel up front along with a cheap factory 16 or 17+ front wheel.
Cool discoveries!
