BUILD THREAD 86 GP 2+2~Blown 6.0
Well started reassembling the heads. Got a little sidetracked and ordered the wrong (factory) valve stem seals instead of the smaller ID set needed for the BTR dual springs. Also I think sent the spring locator seats back with the core engine so had to get replacements of those.
Cleaned up the stock lifters and installed into new trays.
Bolted heads on with some new lsa head gaskets and reused the stock head bolts as it's been tested that unless you spend $350 on a set of ARP studs the reused stockers outperform almost everything.
Cheap 2yr old digital torque wrench wouldn't turn on so broke out Mr. John Deere 1970's swing beam wrench dad gave me 15 years ago.
Dropped the rockers on to find .075 of slack between the spring and rocker. Seems odd as everything is essentially the same type of part as the old lq4 and that ran stock pushrods.
I need to determine if BTR changed the base circle diameter on the series 1 stg2 blower cam I used to have vs my new stg2 torque blower. If so the ~.050 pushrod length change maskes sense. If not IDK
Have a stretch of 16 days off before I go back to work so my goal is to get the engine back in the car by Jan 5th.
Spent the first half entertaining family with Christmas, they are all gone so back to the garage.
Ended up deciding I might need longer push rods but it's hard to measure the length I need now until they pump up and I think dimensionally it's OK enough to run. I sent it and am reusing the factory lifters as they all looked OK. Some might be a bit air logged and that's giving me the funny slop at the rocker measurements but it should be fine.
Cleaned the block off and shot it with some paint-
Started removing about 32 wires (mostly auto trans controls) from the harness that I have been toting around for 9 years
Scrub a dub dubbed the frame and firewall, I never painted any of this in 2015 when I stuck the engine in as I planned to pull the engine shortly after I installed it, well that never happened.
Painted
Got the crank pinned, water pump on, AC bracket, and motor mounts on. The motor mounts are home built by Dad and I in 2015 around a stock truck pan and the engine sits kinda crooked, high, and off center but everything clears so I am keeping them. They were bird sheit welded upside down and blind in the car when I dropped the engine in. I was a bit terrified how little weld there was holding the tabs on so I cleaned them up, welded some missing areas and painted them up.
Also and redid my steam lines. The blower manifold sits really low and leaves almost zero room for any stock steam line kit to fit or anything aftermarket. I had 1/4" copper compression fittings on previously but they intermittently seeped so I just transitioned everything over to brake flare NICOP line on the back and some steel line on the front.
So basically the engine is ready to drop in. I need to get my harness re-loomed which that stuff is supposed to get here Thursday. Maybe get the engine installed Saturday? Then I can lounge and get the trans, accessories, blower, and wiring buttoned up through February.
Just gotta work through this pile...
Got the harness finished up, totaled 39 wires I eliminated. Replaced all the loom and cleaned up some routing.
Also dropped the engine in.
Vacation is done, back to work tomorrow but I met my goal of getting the engine in.
Glad to see it’s coming together and you’re not waiting. Time flies and s*** can go wrong.
Reactions: Tony1968
Hey that's right I have a broken car in my garage.
January was busy and February was cold so haven't been doing anything.
False spring arrived and it's been 50 this week so a sign to get to work. I'm sure we will get another shot of snow in March and the roads have more salt than the rim of a margarita so no opportunity to drive the car yet but definitely time to get it out.
Got a new flywheel ordered for the short crank LS and a new clutch friction as my old one has some odd wear and it's not that much money to replace.
Went to measure the TOB shim thickness and noticed the black was missing a dowel. Must have got pulled out in the trans. Luckily I have a $5 Buick 4.1 block I bought on auction last year so I stole the dowel out of it.
But the new flywheel is in and time to work on getting the clutch, Bell and trans in.
Rough goal is running by April 1
Hour here or there adds up.
Clutch Bell housing and trans and exhaust is in
Accessories and blower are on
Started to route the harness
Need to get the fuel system and coolant hoses connected
Snowed 12" last night so I've got time but trying to set an a goal of getting it running by next week so I can ensure the new engine is healthy
What kind of blower is that again? Clearly not a GM piece. I thought it was something you'd adapted to work?
Ford Eaton GT500 like 2008 piece.
Adapter plate on a cathedral LS lower tub. The IC and intake are all Maggie parts. I bought the upper and lower tub affordably off one of the FB swap pages 10 years ago with a couple cracks. I bought the IC brick, air diverter plates and water manifold as service parts as my setup was missing them. The IC helped IAT's a lot but it's got something to gain.
In retrospect it's terrible for flow. I never realized it but the bottom of the IC brick sits maybe 1/4" off the base of the lower tub. The air is well sealed off on the hot side of the cooler and has to force through which is great, but it has to squeeze and turn a sharp 90 degree turn for it to go to the heads.
These guys make a phenolic spacer I am highly considering (after I just bolted the thing together, figures)
It's a known issue with these early maggie blowers that the IC brick sits too close to the lower intake. Probably wanted to clear the hood so they made it intentionally low.
Ended up giving up on the idea of the spacer as there's only 1/8" between the blower and the hood and I'm not rebuilding my motor mounts and exhaust this late in the game.
I can only run 11.50 legal at sick summer anyway and it's already been 11.10 so I have enough power to get done what I need.
Finished buttoning up the engine and got it running last night after a few days of chasing fuel leaks.
Fired on the first crank, 60lb of idle oil pressure and no clanks or misses from what I can tell.
My wideband o2 isn't powering up (odd because it's the only piece of wiring I didn't touch lol) and it seems a bit rich at idle but otherwise I'm happy at this time.
I am struggling getting the cooling system air bled but I'm sure I'll figure it out.
Also installed my overpriced recovered sun visors after owning the car almost 10yrs...
Snow is basically gone but still a lot of salt. Another few days and a good spring rain storm and we will be ready to get back on the road.
That’s funny right there.
Congrats on getting it running.
No one will throw you out for running faster than your cert until you get into a 9. The tracks will be good - need to let it rip!!
