I’ve researched the 9.5 and the aftermarket is poor. For a truck app it’s fine ( have been looking for one for C20 around 500whp). But you’re well over that.
I have no recommendations that I’ll stand behind, but if I were you, then I’d be looking at a genuine Eaton clutch style posi for your build. There are many people running low 9’s with one. I think you got the double wamboozle ( professional term) on a crappy part and wheel hop.
But this is me, not you.
I’m sticking with the 8.8 and hoping I don’t disintegrate it. only positive is that I look at the disc brakes as axle retainers
I get what your saying about the aftermarket being poor. Nobody is out there doing much to an 9.5. It's strong, but kinda an unkown in the performance world. I can get an aftermarket diff, and if I go aftermarket axles that part doesn't matter much to have support since its custom. The parts I need are available but I get the aftermarket lack there of. Just frustrating the car has gone home on a trailer twice and I am rarely an over build it person but I am boarderline at the overbuild it point.
I agree the next diff (if I stay 8.5) I go with will be an Eaton. However I ruled out the posi style or anything with spider gears. The issue I have is that I am putting so much shock load though the center pin and the spider gears. Eaton themselves doesn't seem to recommend the posi for drag use. They say truetrac or detroit locker.
The detroit locker is $800 vs $500 for the truetrac. I watched the tech operation videos for both on summit and the truetrac seems better since it is always in contact and there is little to no slop in the system. The detroit locker has some springs and seems like it could fail in the same way the govlocks do (some sprags need to engage).
The other thing I need to do is get a line lock on the car and trigger it off with the clutch pedal release somehow. I would really like to have a little tension on the driveline when staged.
The other thing I really have an opportunity for up top is some added timing. I had like 13 degrees and one of the professional tuners that went on the trip said on ethanol with my IAT's it should take at least 18 degrees at the boost I am at.
I have one last chance to get the car to the track in 2 weeks. I think I will get a truetrac ordered and installed next week. If weather cooperates I'll have one last shot to try to get my 11.50 goal before the end of the season. Then probably a frame notch and 15x10 rears.
I guess a few more photos I grabbed.
