I remembered watching Mike's 'brown pants' video that my gopro was on this pass.
It made it about 20ft before it popped. You can see the wheel hop 'shake' for about 1-1.5 seconds before I powered out of it.
500Psi cheapo china sensor. I use several of these right now.
https://www.amazon.ca/dp/B0748BN3YS/?tag=rippca-20
I had the understanding that the mechanical unit doesn't work well and is not recommended with a hydraulic clutch operating system.
Maybe look at a T-MAP sensor from a Doodge?
2015-2017 Dodge T/Map Sensor 68207074AB | My Mopar Parts
2015-2017 Dodge part # 68207074AB - T/Map Sensorwww.mymoparparts.com
At first glance the trutrac looks better than the Yukon. I actually had to add a snap ring between the C clip and the Yukon posi to prevent excessive axle endplay and the truetrac didn't need any!
Hopefully get some gear lube and put the thing back together this weekend.
Just keep those sensors away from heat. My fuel pressure sensor was right above my merge log and downpipe, it can get erratic when it gets too warm.Awesome, that is what I need! I think what I am going to do is buy a pair of single throw double pole switches since I only have 1 temp input from the trans and 1 pressure input from the AC. I can put a 500 psi sensor in the clutch line and a 100 psi sensor in the fuel rail and read my fuel pressure and clutch pressure with just flipping a switch and switching my function in HPtuners. I can read post-blower pre-cooler air temp and pre cooler water temp (maybe get a 3 pole switch) and read post cooler water temp also to see what temp rise I'm getting from the aftercooler and what temp drop I am getting from my heat exchanger.
I could see that mechanical setup not working great. The hydraulic system is about $400 but really what I need. Considering diff's are $500 though it's relatively affordable insurance.
The good news is I work in a hydraulics test lab so I have access to a ton of solenoids and think I can program some controller up to release pressure at a controlled rate, but I'm going to spend more than $400 between parts and design time to make it work so I should probably just bite the bullet.
3 BAR? I am stuck with 2 BAR since I am P01 flex SD. Darn P01 not having the RAM for 3 BAR flex.
Yeah please post feedback as the truetrac I saved for purchase. I already have everything else to upgrade my 8.5" to 30 spline except the Truetrac. Streetbu has one in his Malibu and swears by it.At first glance the trutrac looks better than the Yukon. I actually had to add a snap ring between the C clip and the Yukon posi to prevent excessive axle endplay and the truetrac didn't need any!
