See how at the bottom of the spring in the picture, the coil is almost touching? That's the side that goes on top.
Blake442 said:See how at the bottom of the spring in the picture, the coil is almost touching? That's the side that goes on top.
Bumpin1ohmSS said:Success! 😀 BFM wins everytime. LOL! Got the spindle separated without damaging the ball joint boot. Got the spring out and yep! It was upside down. Corrected it, compressed it and got it back in. Cool. I loosened the lca's up a bit and put the wheels back on. Dropped her on her own weight on she sat perfect. Bounce the front and it dropped just a tad. Sits 26" on both sides (measured from ground to chrome strip on the wheel well) Imma let her sit all night and then jack her back up and tighten everything up. Bleed the brakes and then hit the alignment spot.
Elco Warren 8)
80ELCAMINOFLAKE said:...but the passanger side no brake fluid came out????...
Blake442 said:80ELCAMINOFLAKE said:...but the passanger side no brake fluid came out????...
If the rubber cap was missing, the bleeders often get plugged with dirt and grime.
Remove the bleeder and make sure the passages are totally clear, and try again...
84elko said:Warren, you rolling your el camino yet? how does it ride.
