tc1959 said:I got mine at SJ Discount Tools .com just google it. They have a full line of SEM80ELCAMINOFLAKE said:Looking good family...Where can I get that SEM paint?
THANKS I WILL DO SO RIGHT KNOW...
80ELCAMINOFLAKE said:THANKS I WILL DO SO RIGHT KNOW...
Bumpin1ohmSS said:80ELCAMINOFLAKE said:THANKS I WILL DO SO RIGHT KNOW...
That will be another cool weekend project bruh. Im cleaning the tilt coloumn and plastic part now. I'll have em painted up before work. Making a vid right now also. Imma get one more can of the Blue Mist and spray the whole interior. Take the door panels out, clean em up and hit the striping with some silver and then the blue. Just to freshin things up. I'll wait til Saturday to install the column. Me and the homies Kuruption and Melman will get it crackin and have a cool lil vid....
Elco Warren 8)
Elco Warren where can i grab some of those moog springs, i need some for my elco. My elco is og stock and it sits low. What size of moog springs did u get,and did u get some for the rear as well, what size? Im planning do do my suspension as well. i hope it sits higher so i can slap on those 22 irocs im going to get!! Im might go with pst suspension kit.I wants my irocs to tuck nicely.I know u mention some kind of drop spindles on all four corners correct me if im wrong.Bumpin1ohmSS said:Those look cool bruh. Pretty much the standard chrome 22" iroc. I probably wont be able to find another set like mine tho. But those are clean and no 22jj....
OK gettin my suspension parts together for the Elco. These are the stock parts that came off my SS. I took the upper and lower control arms to work and pressed the old bushing out. Ordered some energy bushings, new ball joints and now Im about ready to get started. Here's what I got so far...
Stock SS upper and lower front control arms with new energy bushings pressed in
New Moog stock front replacement springs
New Wheel bearings
New brake pads and rotors-non x-drilled
Stock Monte SS front and rear sway bar-Cleaning it up-New bushings and endlinks for the front swaybar
Complete front end rebuild kit. Ebay special. Center link, tierods ect....
New rear springs
Airlift 1000 coil spring airbag kit
And some other stuff. To finish off the rear im gonna get a upper/lower trailing arm kit to help with any hopping. Saving for a 383 stroker. I also picked up some rear end gear oil and new gasket. Might as well get er all done up. until I can find a Gnat posi rear :wink:
Pics of the goodies....Lil sandin', primer and semigloss hi temp black will clean em up nicely
New Moog stock front springs and the front and rear sway bar from my SS. Cleanin em up and a fresh coat
Bout to get the old girl sittin right again..
Elco Warren 8)
longie13 said:Elco Warren where can i grab some of those moog springs, i need some for my elco. My elco is og stock and it sits low. What size of moog springs did u get,and did u get some for the rear as well, what size? Im planning do do my suspension as well. i hope it sits higher so i can slap on those 22 irocs im going to get!! Im might go with pst suspension kit.I wants my irocs to tuck nicely.I know u mention some kind of drop spindles on all four corners correct me if im wrong.
