Ok thxI believe your only other option is to find an old housing and weld the control arm mounts and spring perches on yourself.
Ya i hear ya. Its tough to doThey aren't a cheap upgrade. I believe I have around $3500 invested in mine with a spool and a cheap disk brake setup.
R the mounts the same? Or would i have to get the mounts welded on too?Buy a 12 bolt and call it a day, just as strong as the Ford 9"
Ya i just dont have the kind of budgetI have seen 9" rears a few times in rollers (cars with no engine or trans) and they will only be asking a couple thousand, some would be worth buying and either swap rears or take it out and part the rest of the car out.
