I have a Chevy 350 from a 1990 C-1500. The oil sending unit sits in a square elbow fitting on back of the block. (The shaft sits 7/8" from the top of block when screwed in, and the elbow hangs 7/8" perpendicular to the shaft.) The elbow doesn't clear to turn over the intake manifold, which means that 1) I can't tighten it properly. (it might brake or its too lose.) 2) Since, the elbow sticks a bit over the intake manifold, removing the intake manifold now requires at least loosening the brackets on the front of the engine. So, I want to replace the damn thing. This part is listed for a 70-72 Cutlass. Should it work in '90 350 or do I need to piece other fittings together?
