Lowproelco said:V6UnderPressure said:V6UnderPressure said:Which adapter are you using for the brake caliper? I am assuming you are running blazer spindles correct?
I'd imagine that this would be the bracket I need?
http://www.flynbye.com/catalog/i257.html
After that, would the rotor just slide right on the blazer hub with no issues with location of the rotor in regards to the caliper?
Looks like the one I'm using but not sure.... I'm using the Kore3 set up.. has the brackets like that but your also gonna need the pab's that is what bolts to the adapters and what your calipers bolt too... So to make it complete u need the blazer spindles and hubs.... The kore 3 brackets or equivalent, the pab and either ls1 calipers or corrvette calipers.. zo6 rotors and finally pads and the shim kit.... And yes with the bracket and other stuff the rotors slde right on and bolt up....
Sorry, I think I am having a brain fart. What is the PAB?
