A little something to offend everyone
The stuff I had on order finally showed up so I went over and put in a couple hours today.
My fuse box had been soaking in vinegar for a week so I cleaned it off. Came out pretty nice.
I reinstalled and adjusted the underdash clutch and brake push rods and the shifter. Then I installed the fuse box and removed the old accessory panel and a bunch of add-on wiring. I'm really kind of embarrassed about how I did it 8 years ago.
I think I've decided on how I'm going to hide the PCM and new electrical panel. Last thing I did was lay the forward body harness in place and then evaluate the engine harness. Basically everything to the right of the concrete expansion joint goes away. The portion on the left will be about 50% reconfigured.
Those 510s were the bomb I owned a 80 Corolla wagon I miss it.
A couple more hours today. The body harness is basically done except for taping one section. If I powered up the main feed, the lights and wipers should work.
Next step is to lay in the engine harness, take some measurements, and reconfigure some circuits. Then wire in my accessory panel.
I ran across a set of hubcaps in a box. Hung them just to remind myself how they look. Undecided.
