A little something to offend everyone
Yes. Crude but functional. Quad4 flywheel and pressure plate, Datsun clutch disc.
Doesn't look crude. How did you set up the design so that everything lined up? Radially and axially? Creative ends on the oil pan.
Reactions: fleming442
Post #187. I did a super-secret-squirrel search and did not find any more details on the trans swap. Trying not to be the noob here.
There's a place in Australia that makes an adapter for just about every permutation. Castlemain Rod Shop.
And this place:
Someone gave me a 68 Dodge Dart with a slant six and a bound-up 3-on-the-column. I found Kelsey Hayes disc brakes and calipers on RockAuto, so I researched swapping in an S10 T5. I found these places while doing the orange apple research. Mixing disc and PP, yep.
Post #9 explains part of it. IIRC the way i centered it was pretty crude too. I made the adapter and bolted it to the engine. Then I blocked the engine up on it's nose so the flywheel was up. Then I put the transmission on the adapter with the pilot shaft in the bushing. Then I pushed it all the way up, marked it with a scribe. All the way down, marked it. Repeat left, then right. Then I just split the differences and marked to drill the bellhousing holes. Not very scientific but sometimes close enough works out.
Thanks for the details. People like you make me believe anything is possible. I just gotta get over myself and go figger it out.
Armchair enjineer. I can think myself into an inside square corner that no machinist can get me out of....
Several hours today. Dissected the harness and moved some things around as well as added a couple wires and removed a bunch of others.
Then I wrapped it up and laid it out just like it'll be in the car.
After that I fed everything between the heater box and the firewall from the right to the left, then the front half through a hole next to the gas pedal.
And that's where I left it. My O2 sensor and knock sensor wires were just a little too short so I'll need to lengthen each one. Then hook up the interior side, mount the PCM and build the accessory panel.
Nothing major today. Lengthened the knock sensor wire and rerouted the O2 wire to reach. Prepped the copper oil pressure tube and connected the engine end. Replaced the gauges in the panel and an all the wiring to the area. Indicator lights are on order. Little things add up.
