AC in Vegas only blowing 62 degrees
I’m assuming you have it wired up correctly with the relays and that? I can post a picture of how my buddy set up mine if you think it’ll help.
Yep, it's all factory stuff, and ran through the PCM. The coil in the heaterbox was slightly shorter than the one I took out, so I wedged a section of radiator hose in to fill the gap.
I know you said you have all factory stuff but are the fans factory too or is it a different setup?
Also, this is what I’m getting at idle and it’s currently 106 out. There’s gotta be a way to get it colder. Going to stop at the ac shop early to see if I can mock up a different condenser without paying an arm and a leg. I also think my ac is low.
