Alignment problem
Oh I didnt see that they were UMIs I thought he just had some of the speedway style arms, and that there might be a chance he had long ones and could switch to short ones.
I was mistaken, he said G body parts
8".......9 1/2 is used in circle track racing on the left side so you can get lost of positive camber to keep as much of the tire on the pavement in a corner. The right side is the shorter one so you set it up for camber gain in the corner.
Hopefully what you have is longer than 8", then you can buy the shorter ones for an easy fix...
Apparently I have frame sag is there offset shafts I can buy for these arms to get my camber up? I am going to stock specs and it is at -2.5 degree
