Alright thanks, appreciate the info.you can use anything between 35 ohm, 5 watt, and 500 ohm, 1/2 watt
I recommended the diode as it was what I was using and it was working well. That and I was not sure where where to get a correct resistor easily. Any of the three methods will work though.don't you mean resistor?, a diode just regulates the direction of the flow of the current.....
The diode will just prevent the back feed by not let current flow from the alternator back through the wire as opposed to the resistor or light bulb that bleeds it off as heat.
The diode itself provides a little bit of resistance in the forward direction. I think the diode option came about to help out with letting low RPM vehicles start charging closer to idle. Apparently the higher the resistance of the resistor, the higher the RPM that the alternator will switch on for the first time.
All options are good options though.🙂
