What size alternator should I get?
I got my car back on the road with the new motor. I went from a 355ci to a built aluminum headed 408ci Stroker. I decided to go with electric fans off of a 4th gen camaro and an aluminum 2 row radiator. I had everything wired up directly to the igniton until i bought a fan controller. With both fans on all the time the car barely went over 170* in 80* weather. My alternator was barely charging so I went ahead and got the controller and wired it up. Low and high speed works like expected. I have the low speed wired to the ignition and the high speed comes on at ~190*. The vehicle ran at a consistant 185* on the freeway in 90* weather cruising at @ 2600 RPM. At idle, the high speed fan on kicks on for a few seconds every minute or two. The radiator is really doing its job with the fans on low.
The problem I am having now is that with my electric fuel pump, and those dual fans pulling so many amps that my charging is suffering. I havent even turned the radio on and I am already having problems. My system consists of a 400w amp and 2 12" Kicker L7's. I doubt that they will need too much juice since everything worked fine before the fuel pump and fans. So, as stated in the begining, what size alternator should I get?
Any help is greatly appreciated, I am tired of carrying cables around. lol
The fan setup before the 2 row
After the 2 row
After the 2 row
