http://www.p-s-t.com/s.nl/it.A/id.4289/.f?sc=12 i need a good set of rear trailing arms for my 3.73 im putting in my cutty
pencero said:You need boxed if you are going to tow. It also helps if your car has a mild raise for stability. Otherwise it's up to you! I'd say if you're not going to tow save your $$$ - most ppl cant afford new trailing arms those are going to make a big enough difference as it is
Rasheerh said:pencero said:You need boxed if you are going to tow. It also helps if your car has a mild raise for stability. Otherwise it's up to you! I'd say if you're not going to tow save your $$$ - most ppl cant afford new trailing arms those are going to make a big enough difference as it is
ok thanks, i just will buy the umi kit
