if it has a computer controlled carb, get rid of it and the distributor. drop in a properly rebuilt q-jet and a standard HEI distributor. both can be switched to a 350, with minor tweaks, when you go that route.
also, pull the EGR system, AIR system and the other emissions system, except for the carbon canister. eliminate the cats, and run true duals.
also, depending on what trans you have, change the rear gears.
