At a loss......
rubio9800
242
110
California
Changing a fusible link is cheap... you can get one at any auto parts store... changing it may be a knuckle buster depending on where it is located on the firewall / engine... still the only way to eliminate the possibility that it is the culprit...
i will look into this, need to figure out how to
mikester
2,929
3,727
Small town NY
A fusible link isnt anywhere near the firewall. Theres two that are on the starter wires. They look like this. The links are the wire going out of the plastic barrels to the ring connector. The plastic barrels are either black or white and theyre factory butt connectors. Check the link wires for breaks or see if the insulation is burned through. Ground wires go to the frame and firewall.
This what they look like repaired.
This is what they look like repaired
blk7gxn
1,390
1,886
Current flows from the battery through the ignition switch /system, WITH TAHT MUCH Volt/amp output, it sounds like its an overload on that system, perhaps overheating if you will, the coil and components temporarily, and shutting it down as a result. It wasn't meant for that much voltage. Thing is as you start a vehicle up, the alternator will start out max charge and come down slowly, so if that thing is putting out this much while running, imagine what it is as it first starts up! there is defiantly an overload issue here, id dump that alternator and see how it runs with a normal amperage one before you go poking to hard. Good luck!!!
rubio9800
242
110
California
thank you for the pictures. what gauge wire is that ?
rubio9800
242
110
California
ive tried 2 alternators with same result
unless both could have an issue? i got one tested and it passed. the other one just bought last night. should i get another to try?
blk7gxn
1,390
1,886
Question, are these Napa alternators?
scoti
1,986
3,423
Texas
@rubio9800, where are you located? Perhaps there's a site member in your area that could assist your troubleshooting effort.
It usually never hurts to make friends w/another enthusiast that is somewhat local to you.
rubio9800
242
110
California
Wire is 12AWG. The link wire is 16AWG. The repaired links in the photo had two different sizes when I first made them. 16 and 14 but I changed them to both 16 before I put it all back together.
if bad should be fine to just do 12awg all the way? or is that overkill?
blk7gxn
1,390
1,886
Perhaps TOO , a bad pickup coil...just talking aloud here .....
