Backspacing and Offset
stock g-body spacing is 4.75 IIRC
you can use offest or BS and width, but most wheel companies advertise the offset, not the BS.
I think it's 3.75 or maybe 4.
4.75 will most likley put you into the frame.
yeah, sorry 3.75, and i think 4 if you count the lip of the rim
Does anyone kno how wide i can get my back tires. i was thinking of going 275 in the rear but i dont want it to rub..can someone let me kno if it will rub
this a combined problem back spacing & tire buldge ....
cause when a tire buldges pass the rim lip it takes away space between rim and frame ....
at 4.0 b/s with a 275 /50 on a 8 inch rim I doubt it woulndt rub on frame .....specialy in tight curves !
if fits, it will be limit !
the stock 7" rims are at 3.75" b/s .....
As I understand it the most important thing is to get the centerline of the wheel lined up with the middle of the wheel bearings, very important for the fronts, maybe a little leeway on a solid axle rear.
This is to avoid bump steer conditions and putting an offset load on the bearings.
Roger.
I am going the stocker route with my Regal, and I want some real meat in the back. I am looking at 15x10's in the back and 15x8's in front. What kind of back spacing should I be lookin for in the back?
Roger.
we run offset rims on our race car and it has no effect on the bearings. As for bump steer a wheel cannot create or improve a bump steer issue. Here's how we measure and correct the bump steer and it's done without the wheel
images
Reactions: rogue_ryder
i am currantly in the wheel department and want to pick up some 15 x 10 champion wheels i have a ford 9 in that was made to be same length as stock rear was wondering if anyone els on here has 10 in rears and could help out with bs and i plan to run a 9 in slick reason for buying 10 in rim is because next wint i plan to mini tub
Just a lil something I came across:
Reactions: Ace Burt
