80ELCAMINOFLAKE said:Do i connect the brown and green together and then to the "L" on alt??im sick!!
Longroof79 said:A quick question. Your showing the plug from the back of the gauge cluster. Is that disconnected, or do you just have it temporarily unplugged to find where the wire is going?
I wish I was there to help you.. But anyway. Get a length of 14-16 ga. wire. Long enough to connect from the fuse box to the alternator plug. Take your test lamp and find a spare terminal that's hot only when the key is turned on. It might be marked accessories, abbreviated. Run the wire thru the firewall...or outside of the car temporarily.
Use a male spade connector, push it on the spare +12 volt terminal. Connect the other end of that wire to the white wire of that plug. Tape it so it doesn't short. Connect that to your EC-82 adapter, and connect that back on the alternator.
Start the engine, and put your meter across the HOT lug in back of the alternator and ground. You should be getting your 14.0-14.5 volts or so. Sometimes it will take a few seconds for the voltage to come up as it's running.
Just make sure that wire is connected to the resistor.
Longroof79 said:Yes sir, you got it right...sorry to confuse you. The EC-82 already has the resistor in it. Just follow the steps and give it a whirl.
Why I asked you about the plug behind the gauges. When you disconnected it, you also disconnected the GEN. warning light and oil pressure warning light circuits. Which is why the alternator is not energizing...or charging.
Good luck, bro. Hope there's good news. :wink:
==========================================================================================================80ELCAMINOFLAKE said:Koo!!! Bro u dont know how much i hate wires i cant stress it enough![]()
But u have been very helpful to me, and i hope this helps others...u are the MAN!!! i will try it out tomorrow morning, im woking know.. 😢 i will give u an update...thanks again :wink:😀
