What type of side port battery do y’all use ? Or do u suggest I had 4 6x9 speakers
2 12inch subs
And and 2 2000 watts amps
2 12inch subs
Okay going to invest in a another battery for a audio+on the alternator, I use a top post side post battery so I can keep the stereo stuff seperate and not having problems with side post connection to the main power source of the car and a cap that has a digital read out so you get an idea of what your system is drawing
This the alternator I’m using....a bigger alternator.
Okay will doChrome don't get ya home. Get the biggest alternator you can fit. Don't bother messing with A-zone; go find a local starter/alternator/electric motor shop near you.
12v is 12v Not sure if you have done the big 3 upgrade? That should be the first thing done when it comes to after market stereo installs.What type of side port battery do y’all use ? Or do u suggest I had 4 6x9 speakers
2 12inch subs
