Looking for ideas and pictures of battery tray in trunk or what you built or were in trunk you guys put it I'm relocating mine on my tpi swap want to see were best spot
I used a Ford style solenoid, I looked for one that had the longest studs so I could use it as one of my distribution points.I was thinking of same location.. what did you use under hood for solenoid
I'm just running all stock with a 350 tpi cam on a 305 tpi stock everything for now just want the thing running I got my Cummins for now down road I plan 454 carb I also got painless wiring and chip burnt for emissions deleteWhat intake setup are you using for the TPI swap? What all do you still need?
Fyi... I was running a stealthram setup with TPI ecu, painless harness, etc that has since been retired and needs a good home due to finally going turbo LS.
