Hey guys. every day i’m slowly improving the car, but i’m having little luck with the timing. car has an 8.0:1 truck 454, 800cfm edelbrock thunder AVS mechanical secondary carb with a summit vacuum advance HEI unit. running almost stock everything minus cam and valve springs, cam is a .502/.501 and 218/228 at .050, 114 LSA. motor seems to love 18-20 degrees at idle, which causes insanely hard hot starts, and at full advance puts it to 40-42 degrees which seems like quite a bit. i’m new to the whole carb/dist thing as i’ve been an efi guy forever but wanted to learn. running the dist off of ported vacuum right now, would switching to manifold vacuum, re-timing base to 12-14 and limiting vacuum advance to 4-6 degrees or so get me going in the right direction? sorry if this doesn’t make sense i’m new to this stuff haha. thanks!
