CdnCutlass said:I heard with the amount of ethanol in gas now the shelf life is greatly reduced.
That is correct - it also causes harm to rubber components in the fuel system, unlike plain old gasoline.
Tuggy24g said:We did it this way to make the pump constantly pump gas so it would drain out of the tank. The fuel pump only pumps gas for like 2-3 seconds since that is all the gas that is needed to start an engine.. So we wanted it to pump gas constantly to drain the tank. So It was simple and easy to do if you know what your doing.
