Flat top 454 bottom end from the RV.
RPM or similar intake
Closed chambered full size oval port 396 or L29 Vortec-7400 heads
270-280 duration cam
Car oil pan and pick up tube to fit the frame RV and truck pans do not. Need the car clam shells/motor cups....truck is different!
MOOG 5610 front end springs
Stall for the TH400 + shift kit
Hooker 2455 70-81 Camaro headers work with some dents or trimming the lower A-arm mounts
DER-PH057 early small tube headers that fit, slip right in with motor in place, have to trim driver side clam shell/motor cup
You said 9 inch
Brace the frame at the front of the lower control arms and in the torque box.
Add some lower half of the missing body bushings
Dual exhaust cross member
Nitrous???
Or...
Chinese aluminum heads angle milled to 100 or so cc
Keep the flat tops, same parts as above.....I have run many a 781 and 049, now they are not as easy to find....and the aluminum heads get cheaper and cheaper...
Or...
496...
You said 9 inch
Nitrous???
Or...
Or...
496...
