Will one fit in a G without modifications?565bbchevy said:...Assuming you will be buying an aftermarket extra capacity oil pan pretty much anything out there clears your stock 3.75 stroke.
Thanks 83MONTESS. I guess I'll take some measurements while the 350 is in the car.-83MONTESS- said:The oil pan fitment really depends on the headers. If you go the more expensive route with the $400+ gbody specific headers you will probably have more clearance for the starter, oil pan, and oil filter. With the Abody headers the clearance will be tighter and most people use mini starters and remote oil filter kits. I havent seen a 6-7 qt oil pan that wont fit in a gbody and there's no reason to go any bigger.
crucial118 said:Will one fit in a G without modifications?565bbchevy said:...Assuming you will be buying an aftermarket extra capacity oil pan pretty much anything out there clears your stock 3.75 stroke.
